gycuk1's avatar
gycuk1
Apprentice
Nov 13, 2020
Hybrid VPN
Hi
Will the Dumos 3.0 when and if it is ever realsed for the XR700 have Hybrid VPN? I can not seem to find this answer anywhere as i note its been dropped from the XR1000. I know this is an important feature for alot of people and i dont want to break my setup putting 3.0 to find Netgear dropped it.
cheers
    • gycuk1's avatar
      gycuk1
      Apprentice
      Netduma-Fraser wrote:
      As far as I am aware it will still be included in 3.0 for the 700.
      Many thanks, i wish you had built the xr700 or the R2 was the same spec!
