Feekda
Oct 17, 2021Aspirant
HybridVPN
Good evening, I have a problem with the use of Hybrid VPN, I have my subscription to HMA when I put the data, select a city and then select the device that I want to use the VPN the device does not h...
Feekda
Oct 18, 2021Aspirant
Yes, I added the device on the right, but I still do not have the connection to the VPN.
Netduma-Liam
Oct 19, 2021NetDuma Partner
Could you try connecting, then copy the VPN logs and send those over?
- FeekdaOct 19, 2021Aspirant
Wed Oct 20 02:41:56 2021 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Dec 29 2020 Wed Oct 20 02:41:56 2021 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Wed Oct 20 02:41:56 2021 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Wed Oct 20 02:41:56 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Wed Oct 20 02:41:57 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]5.62.61.236:443 Wed Oct 20 02:41:57 2021 Socket Buffers: R=[87380->87380] S=[16384->16384] Wed Oct 20 02:41:57 2021 Attempting to establish TCP connection with [AF_INET]5.62.61.236:443 [nonblock] Wed Oct 20 02:41:58 2021 TCP connection established with [AF_INET]5.62.61.236:443 Wed Oct 20 02:41:58 2021 TCP_CLIENT link local: (not bound) Wed Oct 20 02:41:58 2021 TCP_CLIENT link remote: [AF_INET]5.62.61.236:443 Wed Oct 20 02:41:58 2021 Connection reset, restarting [0] Wed Oct 20 02:41:58 2021 SIGUSR1[soft,connection-reset] received, process restarting Wed Oct 20 02:41:58 2021 Restart pause, 5 second(s) Wed Oct 20 02:42:03 2021 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Wed Oct 20 02:42:03 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Wed Oct 20 02:42:03 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:03 2021 Socket Buffers: R=[87380->87380] S=[16384->16384] Wed Oct 20 02:42:03 2021 Attempting to establish TCP connection with [AF_INET]5.62.61.236:443 [nonblock] Wed Oct 20 02:42:04 2021 TCP connection established with [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:04 2021 TCP_CLIENT link local: (not bound) Wed Oct 20 02:42:04 2021 TCP_CLIENT link remote: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:04 2021 Connection reset, restarting [0] Wed Oct 20 02:42:04 2021 SIGUSR1[soft,connection-reset] received, process restarting Wed Oct 20 02:42:04 2021 Restart pause, 5 second(s) Wed Oct 20 02:42:09 2021 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Wed Oct 20 02:42:09 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Wed Oct 20 02:42:09 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:09 2021 Socket Buffers: R=[87380->87380] S=[16384->16384] Wed Oct 20 02:42:09 2021 Attempting to establish TCP connection with [AF_INET]5.62.61.236:443 [nonblock] Wed Oct 20 02:42:10 2021 TCP connection established with [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:10 2021 TCP_CLIENT link local: (not bound) Wed Oct 20 02:42:10 2021 TCP_CLIENT link remote: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:10 2021 Connection reset, restarting [0] Wed Oct 20 02:42:10 2021 SIGUSR1[soft,connection-reset] received, process restarting Wed Oct 20 02:42:10 2021 Restart pause, 5 second(s) Wed Oct 20 02:42:15 2021 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Wed Oct 20 02:42:15 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Wed Oct 20 02:42:15 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:15 2021 Socket Buffers: R=[87380->87380] S=[16384->16384] Wed Oct 20 02:42:15 2021 Attempting to establish TCP connection with [AF_INET]5.62.61.236:443 [nonblock] Wed Oct 20 02:42:16 2021 TCP connection established with [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:16 2021 TCP_CLIENT link local: (not bound) Wed Oct 20 02:42:16 2021 TCP_CLIENT link remote: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:17 2021 Connection reset, restarting [0] Wed Oct 20 02:42:17 2021 SIGUSR1[soft,connection-reset] received, process restarting Wed Oct 20 02:42:17 2021 Restart pause, 5 second(s) Wed Oct 20 02:42:22 2021 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Wed Oct 20 02:42:22 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Wed Oct 20 02:42:22 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:22 2021 Socket Buffers: R=[87380->87380] S=[16384->16384] Wed Oct 20 02:42:22 2021 Attempting to establish TCP connection with [AF_INET]5.62.61.236:443 [nonblock] Wed Oct 20 02:42:23 2021 TCP connection established with [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:23 2021 TCP_CLIENT link local: (not bound) Wed Oct 20 02:42:23 2021 TCP_CLIENT link remote: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:23 2021 Connection reset, restarting [0] Wed Oct 20 02:42:23 2021 SIGUSR1[soft,connection-reset] received, process restarting Wed Oct 20 02:42:23 2021 Restart pause, 10 second(s) Wed Oct 20 02:42:33 2021 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead. Wed Oct 20 02:42:33 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Wed Oct 20 02:42:38 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:38 2021 Socket Buffers: R=[87380->87380] S=[16384->16384] Wed Oct 20 02:42:38 2021 Attempting to establish TCP connection with [AF_INET]5.62.61.236:443 [nonblock] Wed Oct 20 02:42:39 2021 TCP connection established with [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:39 2021 TCP_CLIENT link local: (not bound) Wed Oct 20 02:42:39 2021 TCP_CLIENT link remote: [AF_INET]5.62.61.236:443 Wed Oct 20 02:42:39 2021 Connection reset, restarting [0] Wed Oct 20 02:42:39 2021 SIGUSR1[soft,connection-reset] received, process restarting Wed Oct 20 02:42:39 2021 Restart pause, 20 second(s)
- Netduma-FraserOct 20, 2021NetDuma PartnerDownload the OpenVPN configuration files from HMA and use it in the Advanced Setup instead of using the basic setup and it should work.
