AZX_
Sep 06, 2022Guide
I’m having some issues with my Xr1000 and would love some help
I’m having some issues with my Xr1000 and would love some help. Particularly ipv6 keeps having issues when enabled. I’m on the latest firmware. Also I’m having speed issues.. pay for 1.2 GB through x...
- Sep 06, 2022
The onboard connection rate app hasn't worked for most of the XR series.
So when you have your ethernet connected PC connected, try using Ooklas installable speed test app and test with this app on the PC thru the router and modem with QoS disabled on the router.
Sep 06, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What are wired speed test results with a wired PC connected behind the CM1200 with out the XR router in the middle?
You'll only get around or maybe just over 900Mpbs when connected at the CM modem. You won't see anything more then that.
Be sure your ethernet adapters are up to date on the PC.
Factory reset the router and setup from scratch.
I would enter in the up and down speed values during the setup wizard or test with QoS disabled on the router with a wired speed test.
AZX_
Sep 06, 2022Guide
Thanks for the swift reply.. again I’m on the latest xr1000 firmware no question. The cm1200 modem gets around 950mb when directly connected and I’ve restart my network adapter countless times. Qos enabled or disabled still gets poor results.. the connection benchmark tool in duma Os consistently gets a d rating for download speeds and they are infect set correctly.
- FURRYe38Sep 06, 2022Guru - Experienced User
- AZX_Sep 06, 2022GuideAlso I just purchased for the second time brand new Ethernet cables.. they are cat8 and the previous were cat7 with same results.
