AZX_'s avatar
AZX_
Guide
Sep 06, 2022
I’m having some issues with my Xr1000 and would love some help
I’m having some issues with my Xr1000 and would love some help. Particularly ipv6 keeps having issues when enabled. I’m on the latest firmware. Also I’m having speed issues.. pay for 1.2 GB through x...
  • FURRYe38's avatar
    The onboard connection rate app hasn't worked for most of the XR series.
    So when you have your ethernet connected PC connected, try using Ooklas installable speed test app and test with this app on the PC thru the router and modem with QoS disabled on the router.
