XxDarkxEchoxX
Oct 31, 2019Aspirant
I cannot get a open nay type
I’m playing COD MW on PS4. I have a type 2 nat type in network setting via the PS4. In game my nat type is moderate. I have port forwarded I have put into dmz. I’ve read the tutorial from this site to...
Oct 31, 2019Guru - Experienced User
uPnP is only needed for one game console online at one time. No PF configurations is needed. DMZ is not recommended. NAT type 2 will be the most you'll seen with the PS behind any external router connected to a ISP Modem that doesn't have a built in router.
- Netduma-FraserNov 02, 2019NetDuma PartnerIt's likely the Geo-Filter causing a misreading. Put the Geo-Filter device in Spectating Mode then boot up the game - if it is open then it was a misreading and you can enable the filter again and ignore it if it says moderate in future.
