EnVy_Hype
Jan 07, 2019Aspirant
I don't have hybrid vpn
I have recently upgraded to the the latest firmware. I live in China and I waited so long for the newest features. I am running the latest software, I have ping assist and auto ping. It doesn't have h...
Jan 07, 2019Guru - Experienced User
Hybrid VPN is selectable between Network Montor and System Information:
Enable
Block Traffic If VPN Disconnects
VPN SETUPInformation
Logs
| Provider | N/A |
| Username | N/A |
| Country | N/A |
| City | N/A |
| Protocol | N/A |
| Status | No VPN configured |
- Netduma-FraserJan 08, 2019NetDuma PartnerIt may be that due to your location it has been disabled, instead you should have the option to use a specific Chinese gaming VPN in the Settings
- EnVy_HypeJan 08, 2019AspirantI can't see it, and I don't have it.
- EnVy_HypeJan 08, 2019AspirantI just can't see it and is not in my options.
- FURRYe38Jan 09, 2019Guru - Experienced User
I would try this, download the v40 FW again from the support site. Use IE11 or FF browser to re-load the FW file. Let the process complete. Log in and go to Advanced Settings/Backup. Select Erase do to a full factory reset.
Clear ALL browser caches. Then exit the browser.
Relaunch the browser and walk thru the setup wizard. After it completes, do you see HyridVPN in the routers menu?
