EnVy_Hype
Jan 07, 2019Aspirant
I don't have hybrid vpn
I have recently upgraded to the the latest firmware. I live in China and I waited so long for the newest features. I am running the latest software, I have ping assist and auto ping. It doesn't have h...
Jan 10, 2019Guru - Experienced User
could it be that VPN is not supported in China?
- Netduma-FraserJan 10, 2019NetDuma PartnerI believe it's triggered by the interface language, change it to your native language, does the Chinese VPN appear in settings then? Also didn't see a screenshot of settings
- EnVy_HypeJan 10, 2019Aspirant
It has vpn service but I had it in all previous versions and no vpn client.
I believe it's triggered by the interface language, change it to your native language, does the Chinese VPN appear in settings then? Also didn't see a screenshot of settings - EnVy_HypeJan 10, 2019Aspirant
I believe it's triggered by the interface language, change it to your native language, does the Chinese VPN appear in settings then? Also didn't see a screenshot of settingsWhen I also reset the router it doesn't show hybrid vpn.
I believe it's triggered by the interface language, change it to your native language, does the Chinese VPN appear in settings then? Also didn't see a screenshot of settings- Netduma-FraserJan 11, 2019NetDuma PartnerSo you're saying that Funjsq screenshot is only a service and not a client to VPN the router?
