Gordian7
Sep 20, 2022Follower
I get dos
In my log it say dos attack and my Internet goes off I need help as to why it’s happong I have a net gear xr500
Netduma-Fraser
Sep 22, 2022NetDuma Partner
The DoS entries are quite normal for Netgear routers, it's unlikely they're specifically causing the problem. How often is the internet disconnecting? Does it reconnect on its own, if so how long does that take? If not do you need to do a reboot or reset to restore it?
michaelkenward
Sep 22, 2022Guru - Experienced User
Does this mean that writing those entries is unlikely to overload this router's processor?
Disabling the recording of those entries, along with turning off QoS and traffic metering, has been one suggestion for dealing with troublesome routers.
- Netduma-FraserSep 22, 2022NetDuma Partnermichaelkenward Very unlikely, the router would be dealing with those connections anyway so writing it to the log would be minimal additional processing. Unless it's literally flooding the log constantly all the time then there wouldn't in my opinion be any need to turn off those entries.
- michaelkenwardSep 22, 2022Guru - Experienced User
Thanks for that.
I assume that QoS and traffic metering aren't quite the same.
