ahmer_ali78677
Sep 24, 2024Aspirant
I have 20ms ping in pubg game, but still experience no response time
I have two routers: the main modem, a Huawei HG8145V5, and an XR1000, which I bought for better response time in PUBG. However, my smaller router performs better in PUBG than the XR1000, giving me be...
Netduma-Fraser
Sep 24, 2024NetDuma Partner
Were you actually experiencing any lag or connectivity issues with the game? If you weren't and that's also the lowest ping you can achieve it's unlikely you'll get much better with the XR. The router works best when you're having issues and so there is room for improvement, it will help to make it more stable for you overall but you may not see a specific ping improvement.
Anyway, if we assume there is some room for improvement: How have you set the Huawei to ensure all traffic flows to the XR? E.g. XR in its DMZ, modem/bridge mode. Are ALL devices connected to the XR or do you still have some connected to the HG? How have you setup QoS/Geo-Filter?
ahmer_ali78677
Sep 25, 2024Aspirant
I have a 20ms ping on both routers, the Huawei and the XR1000, but I’m facing an issue in-game. When I shoot at an enemy, my bullets aren’t registering, and after just 1 or 2 shots from them, I’m down. The XR is connected to the Huawei through a dynamic IP, and I’m only connected to the XR, with no other devices on the Huawei. I’ve also set up QoS, so what could be the problem?
- ahmer_ali78677Sep 25, 2024Aspirant
I have a stable ping on both routers, but there’s a difference in response time and bullet registration. I get better bullet connectivity with the Huawei than with the XR. If I buy the Huawei for $5 and the XR for $500, there should be an improvement in bullet registration and response time, as well as a more stable connection to the server.
- Netduma-FraserSep 26, 2024NetDuma PartnerPing doesn't really work like that, if that is the fastest you can possibly achieve due to your base ping/proximity to a game server then the router can't improve that, to do so would literally break the laws of physics and it's not quite at that level.
Is the ping on the Geo-Filter and in game reading the same? Does it suffer from spikes or any sort of instability? It could be server load in which case forcing servers slightly further away even if the ping is slightly higher can result in a better experience if the server is under less load.- ahmer_ali78677Sep 26, 2024Aspirant
When I put PUBG Mobile on the geo-filter, my ping increases in the game. Also, if I reduce the radius to just my country, the in-game voice chat stops working, but if I increase the radius to Europe, the voice chat works. Additionally, PUBG Mobile is not available on the ping heatmap. There are several areas where this router could be improved. It doesn’t properly support PUBG, and I bought it to optimize my routing to PUBG servers and reduce lag by selecting the best server for me. Overall, I was expecting a better routing system. If you have any suggestions to improve my PUBG Mobile ping or recommend another router that could enhance the routing system, I would appreciate it.
Also, my friend plays with 120+ ping, and his bullet registration is far better than mine, even though his internet speed is lower and he’s just using a simple ISP router, not a gaming router.
