ahmer_ali78677
Sep 24, 2024Aspirant
I have 20ms ping in pubg game, but still experience no response time
I have two routers: the main modem, a Huawei HG8145V5, and an XR1000, which I bought for better response time in PUBG. However, my smaller router performs better in PUBG than the XR1000, giving me be...
Netduma-Fraser
Sep 27, 2024NetDuma Partner
You need to add the chat server to your allow list, then you can connect regardless of your radius size/location. Invite them to a chat, check the map for an icon that appears then ping and allow it - you may need to do it a couple of times.
Have the device added to the Geo-Filter, connect to a game, take a screenshot of the map with that server being pinged. Then switch to Spectating Mode, reboot the mobile, play again and do the same screenshot please, then I can compare.
ahmer_ali78677
Sep 30, 2024Aspirant
Leave that for now; I have a few questions. Please just give me a reply.
1_When I connect XR to HG through Ethernet, the ping to the Middle East on XR fluctuates between 11 to 40 ms, while on HG, the ping is between 5 to 11 ms. Since it's a WiFi 6 and gaming router, why is the ping higher?
2_When I connect my mobile to WiFi, after 1-3 hours, the WiFi disconnects automatically, and I need to restart or hard refresh. After that, it works again, but only the 2.4 GHz band shows up, not the 5 GHz. When I hard refresh the mobile, the 5 GHz appears. I'm facing this issue on both my iPhone 14 Pro Max and iPhone 15 Pro Max.
3_Can you suggest any settings, like DMZ or anything else, that could improve my ping without using Geo-Filter?
Let me know if you'd like any further adjustments!
