ahmer_ali78677
Sep 24, 2024Aspirant
I have 20ms ping in pubg game, but still experience no response time
I have two routers: the main modem, a Huawei HG8145V5, and an XR1000, which I bought for better response time in PUBG. However, my smaller router performs better in PUBG than the XR1000, giving me be...
Netduma-Fraser
Oct 04, 2024NetDuma Partner
For 5GHz WiFi change the mode to 2400MBps I think it is, then apply, do you see it working then?
ahmer_ali78677
Oct 05, 2024Aspirant
Netduma-Fraser
still not showing on mobile and working properly on the laptop I check all MBS 600 to 4800
- Netduma-FraserOct 05, 2024NetDuma PartnerChange it to the mode I mentioned, disable any advanced WiFi options like AX then reboot the router, does it work then?
- ahmer_ali78677Oct 07, 2024Aspirant
Netduma-Fraser
Forget the Wi-Fi issue for now, it's still not showing. Can you help with the geo-filter? I set the geo-filter, but I keep getting connected to the same server, which shows 5ms ping, and it automatically appears and disappears in the auto-ping tab. The IP 43.245.206.1 to 254. However, I'm experiencing bullet delay sometimes. Some days my internet works perfectly, but other days it doesn't. Enemies' shots register even when I'm behind cover. I've tried different tools to track the IP, and it always shows me that same address. Is there anything I can do to improve my ping to this IP? - Netduma-FraserOct 07, 2024NetDuma PartnerCan you provide a screenshot of the full Geo-Filter page showing what you see when you connect to this server please?
Does the in game ping reflect 5ms also? - ahmer_ali78677Oct 08, 2024Aspirant
The in-game ping ranges from 10 to 40, while in matches, the ping is 20. However, the geo-filter shows 5ms.
Netduma-Fraser
The traffic prioritization sometimes works when I start the game, but other times it doesn't. Why is that? - Netduma-FraserOct 08, 2024NetDuma PartnerYou need to set Ping Assist to 0 and also if it's the server within your radius then you'll always be able to connect to it, you'll need to adjust the radius to exclude it. I'm not sure how tested the game is so it would be better to add your device with the Games Console service and then it will prioritize the game more consistently.
If I reduce the ping assist to 0, it always connects to the same server. When I switch the device to a game console, the response time doesn't improve; it decreases. How can I set a static IP for this server (43.245.206.1)? Also, why is traffic prioritization inconsistent—sometimes working, sometimes not? I read the article you shared, which suggests setting ping assist between 30 and 50. Previously, I had it set to 0, but it still connected to the same server.
I think the XR1000 firmware needs significant improvements because the 5G isn’t working properly for mobile phones, and traffic prioritization isn’t functioning well. The HG provides a more stable ping than the XR1000, the XR1000 needs improvements in certain areas.
- Netduma-FraserOct 08, 2024NetDuma PartnerThen you need to exclude that server from your radius so you no longer connect to it.
I don't mean switch the device to a Games Console, just add the device to Traffic Prioritization and select the Games Console option to prioritize.
What do you mean 5GHz isn't working properly for phones? - ahmer_ali78677Oct 08, 2024Aspirant
Did you mean like this? Check the picture below—setting the games console to traffic prioritization.
Also, 5G is not showing on my mobile devices. I tested it on an iPad M4, Samsung’s latest model, and an iPhone 15 Pro Max, but 5G only shows up on my laptop. When I hard reset my mobile, 5G appears for the first time, but after connecting, it disconnects automatically after 2-3 hours, and I have to hard reset my mobile again.
I also reduced my area to exclude that server. I’ll play the game and see which server it connects to.
- Netduma-FraserOct 08, 2024NetDuma PartnerYes that's correct for Traffic Prioritization. You have to set Ping Assist to 0, if you don't, you will keep getting that server. Also if there isn't a server within your range you will not get a server. Disable the advanced WiFi options I mentioned before and try again. You may also need to change the channel depending on what is allowed in your country.
- ahmer_ali78677Oct 10, 2024Aspirant
I set the ping assist to 0 and selected my country, but now it keeps connecting to the old bad server with IP 43.245.206.1, which is available in my country. Before making this change, I occasionally connected to the Singapore server, which had a good 5ms ping.
I have a question: I’m playing in international scrim tournaments, and one of my friends, who also plays, has a higher in-game ping than me, around 150-120ms, while mine is 80ms. However, his bullet registration seems much better than mine. His shots register properly, while mine don’t. Sometimes, I get knocked out in 2 bullets, but I don’t see all of his shots, though his fire rate looks normal when I watch the death replay. In my view, he shoots me very quickly.
Also, if I disable advanced WiFi settings like AX, what’s the benefit of having AX in the router if I can’t use it?
Singapore server which I saved
- Netduma-FraserOct 10, 2024NetDuma PartnerIs that server within your radius? If so you will probably connect to it, only have the servers you want inside your radius with any other servers outside your radius. Move the location, adjust the radius size etc to achieve this - it doesn't need to be set to your precise location. They may be experiencing lag compensation, as their ping is so high so the game gives them an advantage to try and make it move even. More so to disable beam forming, mu-mimo etc rather than AX specifically.
- ahmer_ali78677Oct 11, 2024Aspirant
Netduma-Fraser
already disabled - ahmer_ali78677Oct 11, 2024Aspirant
i disabled everything still not showing
- Netduma-FraserOct 11, 2024NetDuma PartnerI can't see the screenshots until they've been moderated, can you attach them directly please?
- Netduma-FraserOct 11, 2024NetDuma PartnerI don't have access to view the second one but I mean in Advanced Settings > Advanced WiFi Settings
Netduma-Fraser
I have already disabled all the advanced settings for 5G, which can be found under Settings > Advanced Settings > Wireless Setup. - ahmer_ali78677Oct 19, 2024Aspirant
