ahmer_ali78677
Sep 24, 2024Aspirant
I have 20ms ping in pubg game, but still experience no response time
I have two routers: the main modem, a Huawei HG8145V5, and an XR1000, which I bought for better response time in PUBG. However, my smaller router performs better in PUBG than the XR1000, giving me be...
ahmer_ali78677
Oct 08, 2024Aspirant
Netduma-Fraser
The traffic prioritization sometimes works when I start the game, but other times it doesn't. Why is that?
Netduma-Fraser
Oct 08, 2024NetDuma Partner
You need to set Ping Assist to 0 and also if it's the server within your radius then you'll always be able to connect to it, you'll need to adjust the radius to exclude it. I'm not sure how tested the game is so it would be better to add your device with the Games Console service and then it will prioritize the game more consistently.
- ahmer_ali78677Oct 08, 2024Aspirant
If I reduce the ping assist to 0, it always connects to the same server. When I switch the device to a game console, the response time doesn't improve; it decreases. How can I set a static IP for this server (43.245.206.1)? Also, why is traffic prioritization inconsistent—sometimes working, sometimes not? I read the article you shared, which suggests setting ping assist between 30 and 50. Previously, I had it set to 0, but it still connected to the same server.
- Netduma-FraserOct 08, 2024NetDuma PartnerThen you need to exclude that server from your radius so you no longer connect to it.
I don't mean switch the device to a Games Console, just add the device to Traffic Prioritization and select the Games Console option to prioritize.
What do you mean 5GHz isn't working properly for phones? - ahmer_ali78677Oct 08, 2024Aspirant
Did you mean like this? Check the picture below—setting the games console to traffic prioritization.
Also, 5G is not showing on my mobile devices. I tested it on an iPad M4, Samsung’s latest model, and an iPhone 15 Pro Max, but 5G only shows up on my laptop. When I hard reset my mobile, 5G appears for the first time, but after connecting, it disconnects automatically after 2-3 hours, and I have to hard reset my mobile again.
I also reduced my area to exclude that server. I’ll play the game and see which server it connects to.
- Netduma-FraserOct 08, 2024NetDuma PartnerYes that's correct for Traffic Prioritization. You have to set Ping Assist to 0, if you don't, you will keep getting that server. Also if there isn't a server within your range you will not get a server. Disable the advanced WiFi options I mentioned before and try again. You may also need to change the channel depending on what is allowed in your country.
- ahmer_ali78677Oct 10, 2024Aspirant
I set the ping assist to 0 and selected my country, but now it keeps connecting to the old bad server with IP 43.245.206.1, which is available in my country. Before making this change, I occasionally connected to the Singapore server, which had a good 5ms ping.
I have a question: I’m playing in international scrim tournaments, and one of my friends, who also plays, has a higher in-game ping than me, around 150-120ms, while mine is 80ms. However, his bullet registration seems much better than mine. His shots register properly, while mine don’t. Sometimes, I get knocked out in 2 bullets, but I don’t see all of his shots, though his fire rate looks normal when I watch the death replay. In my view, he shoots me very quickly.
Also, if I disable advanced WiFi settings like AX, what’s the benefit of having AX in the router if I can’t use it?
Singapore server which I saved
- Netduma-FraserOct 10, 2024NetDuma PartnerIs that server within your radius? If so you will probably connect to it, only have the servers you want inside your radius with any other servers outside your radius. Move the location, adjust the radius size etc to achieve this - it doesn't need to be set to your precise location. They may be experiencing lag compensation, as their ping is so high so the game gives them an advantage to try and make it move even. More so to disable beam forming, mu-mimo etc rather than AX specifically.
- ahmer_ali78677Oct 11, 2024Aspirant
Netduma-Fraser
already disabled - ahmer_ali78677Oct 11, 2024Aspirant
i disabled everything still not showing
- Netduma-FraserOct 11, 2024NetDuma PartnerI can't see the screenshots until they've been moderated, can you attach them directly please?
- Netduma-FraserOct 11, 2024NetDuma PartnerI don't have access to view the second one but I mean in Advanced Settings > Advanced WiFi Settings
Netduma-Fraser
I have already disabled all the advanced settings for 5G, which can be found under Settings > Advanced Settings > Wireless Setup. - ahmer_ali78677Oct 19, 2024Aspirant
