ahmer_ali78677
Sep 24, 2024Aspirant
I have 20ms ping in pubg game, but still experience no response time
I have two routers: the main modem, a Huawei HG8145V5, and an XR1000, which I bought for better response time in PUBG. However, my smaller router performs better in PUBG than the XR1000, giving me be...
ahmer_ali78677
Oct 10, 2024Aspirant
I set the ping assist to 0 and selected my country, but now it keeps connecting to the old bad server with IP 43.245.206.1, which is available in my country. Before making this change, I occasionally connected to the Singapore server, which had a good 5ms ping.
I have a question: I’m playing in international scrim tournaments, and one of my friends, who also plays, has a higher in-game ping than me, around 150-120ms, while mine is 80ms. However, his bullet registration seems much better than mine. His shots register properly, while mine don’t. Sometimes, I get knocked out in 2 bullets, but I don’t see all of his shots, though his fire rate looks normal when I watch the death replay. In my view, he shoots me very quickly.
Also, if I disable advanced WiFi settings like AX, what’s the benefit of having AX in the router if I can’t use it?
Singapore server which I saved
Netduma-Fraser
Oct 10, 2024NetDuma Partner
Is that server within your radius? If so you will probably connect to it, only have the servers you want inside your radius with any other servers outside your radius. Move the location, adjust the radius size etc to achieve this - it doesn't need to be set to your precise location. They may be experiencing lag compensation, as their ping is so high so the game gives them an advantage to try and make it move even. More so to disable beam forming, mu-mimo etc rather than AX specifically.
- ahmer_ali78677Oct 11, 2024Aspirant
Netduma-Fraser
already disabled - ahmer_ali78677Oct 11, 2024Aspirant
i disabled everything still not showing
- Netduma-FraserOct 11, 2024NetDuma PartnerI can't see the screenshots until they've been moderated, can you attach them directly please?
- Netduma-FraserOct 11, 2024NetDuma PartnerI don't have access to view the second one but I mean in Advanced Settings > Advanced WiFi Settings
Netduma-Fraser
I have already disabled all the advanced settings for 5G, which can be found under Settings > Advanced Settings > Wireless Setup. - ahmer_ali78677Oct 19, 2024Aspirant
