rippajohn
Feb 13, 2022Tutor
I have a X1000 Router, and im having issues!
Hi there, I purchased this router around three months ago, and it has been a nightmare. When it works its great, but i always have problems with internet connection. I have three computers connecte...
michaelkenward
Feb 14, 2022Guru - Experienced User
Your subject says:
"I have a X1000 Router"
I can't find that in the Netgear system. Do you mean XR1000?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- rippajohnFeb 14, 2022Tutor
Thanks, I will post it there.
