TheSpartan
Nov 22, 2022Aspirant
I have been using XR1000 for almost an year
Here are my issues, Firmware is broken. I had waited for firmware updates to get the issues fixed but the issues are still there, for example QOS upload speed limit doesn't work even if I uncheck Uplo...
TheSpartan
I made a video, but the screenshot sums up everything.
Edit: I have attached a screenshot with a different address I used to test it.
Netduma-Liam
Nov 23, 2022NetDuma Partner
ARP will show you the MAC address of the LAN interface on the XR, whereas the MAC address shown in the interface is the MAC address of the WAN interface.
- TheSpartanNov 23, 2022Aspirant
When I tested it before to setup the router for the first time it didn't work. My ISP only allows their own router, so I set the MAC as the same as the ISP provided router, it didn't work but later my ISP added the default MAC address of the router to my account so it's working now. Can you look into my other issue, why the router doesn't limit Upload speed through congestion control and Bandwidth allocation even if i uncheck upload share excess. Checkout the screenshots. I have 10 devices connected at most concurrently but it usually 6 devices.
