TheSpartan
Nov 22, 2022Aspirant
I have been using XR1000 for almost an year
Here are my issues, Firmware is broken. I had waited for firmware updates to get the issues fixed but the issues are still there, for example QOS upload speed limit doesn't work even if I uncheck Uplo...
TheSpartan
Nov 24, 2022Aspirant
Even if I turn off ipv6 the QOS issue is still there.
Netduma-Fraser
Nov 24, 2022NetDuma Partner
Do you use PPPoE as well as IPv6 or VLAN? Have you put a device in the DMZ? How did you disable QoS exactly?
- TheSpartanNov 25, 2022AspirantI have confirmed with my isp that they uses PPPoE. I haven't put any device in the dmz but I have port forwarding for a service and UPnP. I didn't disable QOS. I use QOS to reserve bandwidth for heavy tasks such as game streaming and meeting. QOS on xr1000 don't have any effect on upload speed.
- Netduma-LiamNov 25, 2022NetDuma Partner
That would explain it, this is a known issue with QoS and PPPoE, we should have that resolved for the next version.
Are you able to configure these PPPoE settings on the ISP modem instead?
If not, do you have any other routers you can put inbetween the XR and the modem? You can then configure PPPoE on that router, disable it's Wi-Fi and put the XR in it's DMZ.
