Compoza_
Mar 14, 2021Luminary
I have no hope for the QoS
The QoS is totally broken in my opinion, my ISP internet speed is 500/100 mg. This is without QoS: https://imgur.com/a/wMARwGf And this with QoS enabled, I have allocated all the total bandwi...
- Mar 14, 2021
I had the Share Excess not enabled, but now 3 minutes ago, I changed the numbers for download speed and upload speed to 1000 MB both, https://imgur.com/a/TJmHBDv to see if it works, and the download speed actually increased! https://imgur.com/a/ka3z5tN
Before I'v had set the download and upload speed 500/100, that's my ISP internet speed, and the test wasn't good, but when I set the speed 1000/1000 mb instead, I got more downloadspeed. Is there any way to increase to 2000/1000 mg speed to get more of the actual download bandwitdh speed from my ISP's internet? Otherwise, it's definitetly a bug in the firmware.
Netduma-Fraser
Mar 14, 2021NetDuma Partner
I assume you have allocated all bandwidth to the computer via Bandwidth Allocation but with Share Excess enabled which means there are some other devices on your network which need the bandwidth which is why you're not getting full speeds.
Compoza_
- Netduma-FraserMar 14, 2021NetDuma PartnerNot possible to set it any higher than that, can you provide a screenshot of your entire QoS page please as I may be able to see what is happening.
- Compoza_Mar 14, 2021Luminary
Now I get the full download speed with QoS enabled! I don't know why it is good now, maybe because the router neeeded longer to adapt.
- Netduma-FraserMar 14, 2021NetDuma PartnerThat's odd, it could have been ISP congestion or the servers under load when you were testing previously. Keep us updated on what happens.
