josephquake
Feb 12, 2021Tutor
I have the Antibufferbloat wrongly configured
It does not detect all my bandwidth to do it I have to set it to 1000 when it should only be set to 450 but when doing so it only detects 250 megabytes and it does not detect all my real bandwidth wh...
Netduma-Liam
Feb 12, 2021NetDuma Partner
In 'Set Bandwidth speeds', you need to change these to your actual upload and download speeds you get from your ISP. If it is not correctly detecting your speeds automatically, you can also enter them manually.
josephquake
Feb 12, 2021Tutor
when I put the amount of real bandwidth when doing speed test it gives me less than 250 and when I do it with 1000 it gives me my real bandwidth
- Netduma-FraserFeb 12, 2021NetDuma PartnerYou have set the sliders to 240, that is why you're receiving those speeds. Enter your correct speeds as above, put the sliders at 100% and you'll receive your speeds.
- josephquakeFeb 12, 2021Tutor
it's still the same I put it at 100% and 400 megabytes and it only gives me 280 megabytes
- Netduma-FraserFeb 12, 2021NetDuma PartnerCan you provide a screenshot of what your QoS page looks like now please?
