Raulsalgado140
Sep 28, 2019Follower
I have xr300 and most of the menu wont show up like qos or the geo filter. I'm stuck with settings
Iv'e tried to see if it was just happening on chrome but it's also happened on other internet browsers too. Can someone please help.
Sep 28, 2019Guru - Experienced User
So FireFox or Opera experience same thing?
Be sure to clear ALL browser caches, exit then re-launch the browser and then navigate to the routers web page.
Netduma-Fraser
Oct 01, 2019NetDuma Partner
Definitely perform a factory reset either from Settings > Administration > Backup Settings > Erase if you're able to or hold the reset button in the back of the router down for 30 seconds.
