MJoplin
Mar 30, 2020Aspirant
I increased my ISP speeds - when I speed test from the Router I get good results, My Cat 5e Ethernet
I pay for a pretty decent speed from my ISP (just bumped it up). When I do a speed test from the Router, I get the full 20MB speed however, my laptop which is connected via Ethernet 5e cable still o...
Mar 30, 2020Guru - Experienced User
did you setup qos on the R8000P?
I've heard of prior settings being retained even through a reboot.
Have you tried a simple factory reset and re-install?
- MJoplinMar 30, 2020AspirantYes, I set QoS. Should I not have? I'm trying to attain fast enough signal to sustain VoIP to my remote office over VPN.
- plemansMar 31, 2020Guru - Experienced User
what modem are you using?
have you tried a reset and re-install?
- MJoplinMar 31, 2020Aspirant
I have a nighthawk Tri Band Router on the latest firmwre. I'm hoping to not have to do a factory reset, because of all of my IoT devices - plus I work online about 10-12 hours per day. However, if it comes to that - that is what I will do. I'm actually considering putting my Ethernet from my work PC into a hub that I will connect to my ISP. Because I am so rural, I use Airlink Internet (wireless network is powered by a proprietary point to multipoint technology and leverages the available 5G spectrum for unparalleled performance and reliability). My modem test showed 20MB/s Down and 10 MB./s Up - However, My ethernet gets choked down to 3-5 MB down. I need VOiP to function reliably. I end up making 20+ work related calls over a softphone/VPN every day. Sometimes the audio is just absent from the other caller only 10% of the time, but that's enough to be problematic.
