Dynaxr500's avatar
Mar 10, 2020
I lag when my modem (arris) is set on bridge and i get my static public address router xr500
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Mar 10, 2020
    If you use the DMZ so it is arris (XR in DMZ) > XR500 then you shouldn't have a double NAT as it has a direct line to the WAN. PS4 NAT Type 2 is open it just means it is behind a router compared to Type 1 which is connected to a modem.
