Dynaxr500
Mar 10, 2020Guide
I lag when my modem (arris) is set on bridge and i get my static public address router xr500
- Mar 10, 2020If you use the DMZ so it is arris (XR in DMZ) > XR500 then you shouldn't have a double NAT as it has a direct line to the WAN. PS4 NAT Type 2 is open it just means it is behind a router compared to Type 1 which is connected to a modem.
Dynaxr500
Mar 10, 2020Guide
thanks for the fast response i had it like that and i didn't have any problems but i though that maybe i had double nat thats why i put my modem on bridge if i remove bridge mode i will not have double nat?
Netduma-Fraser
Mar 10, 2020NetDuma Partner
- Dynaxr500Mar 10, 2020Guide
I see thank u very much for the help man
