manloz
Aug 14, 2019Tutor
I ordered the Nighthawk AC2300 R7000P, but reveived the AC2400. Which router is better?
Hello, I recently bought a new router since it has been 5 years since I bought my last. I ordered the R7000P, but I received the AC2400 instead. I compared them both on the website, but I am not ...
- Aug 14, 2019Hi there, it would probably get you better answers if you were to post here for the router you have: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
manloz
Aug 14, 2019Tutor
I should have prefaced that I plan on returning it regardless, but I was curious. If the AC2400 is better, I'll simply cancel the R7000P order and order the AC2400
Netduma-Fraser
Aug 14, 2019NetDuma Partner
- manlozAug 14, 2019Tutor
Thank you, I'll post it there.
