Rick6922
Aug 03, 2019Luminary
I wouldn't recommend NG to my worse enemy. lol
let me start this out by saying I'm 51 yo and been buying the latest and greatest for 30 years, I've had noithing but trouble since buying the NH xr700, the fw 's been updated numerous times , basic...
-Donovan-
I feel you, I'm in the same situation with my XR700.
They recently released a Hot-Fix but many bugs are still there from previous versions. You can find here:
https://kb.netgear.com/000061118/XR700-Firmware-Version-1-0-1-18-Hot-Fix
Note: Make sure you perform a factory reset right after you update your firmware.
- Rick6922Aug 03, 2019Luminary
I did all the steps with that beta FW, it didnt work for me. tks. for the reply though.
