TristanUzumaki
Jun 27, 2020Aspirant
IF I POWER ON MODEM BEFORE XR500 I GET NO INTERNET
I cannot power on the modem and complete a normal power cycle before I plug in and turn on my new xr500 router. If I try to complete a normal power cycle as done with literally all routers I will hav...
Netduma-Fraser
Jun 27, 2020NetDuma Partner
I don't think that would cause you any issues, it's just not establishing a connection at that time for some reason. Are you using dynamic or static settings for Internet Setup?
TristanUzumaki
I am using dynamic and pulling from ISP
- Netduma-FraserJun 28, 2020NetDuma PartnerSet a static/reserved IP in Internet Setup instead please and apply, then see if it continues after that.
- TristanUzumakiJun 29, 2020Aspirant
Do you mean under Internet Setup check and use "Use Static IP Address"?
Or just reserve an IP under LAN Setup?
- Netduma-FraserJun 30, 2020NetDuma PartnerExactly, use 'Use Static IP Address'.
