Felix24343
Jul 20, 2020Aspirant
IKEv2 with MR1100
Hey all, I was wondering if anyone had used the MR1100 to connect to VPN on IKEv2? I have had issues connecting to my work VPN using this protocol and wondered if anyone else had this experience?...
Felix24343
Hi All,
Further to this I have also tried using my old AC800s and have got the same issue of trying to connect to my work vpn.
I have tried the following with both Modems:
VPN Passthrough
DMZ mode to static IP
My work vpn uses UDP ports 500 and 4500 but I cannot connect.
It cannont find in the web interface anything to make sure these ports are open.
I have been able to use an old huwawei modem and connect fine.
Any help appreciated.
Cheers,
Felix
- Netduma-FraserJul 20, 2020NetDuma PartnerSounds like you have a different router to the XR series so would recommend posting in the Nighthawk section: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
- Felix24343Jul 21, 2020Aspirant
Hi Netduma,
I have tried this with two netgear routers:
The Netgear Nighthawk M1 MR1100
And the Netgear AC800s.
I am wondering if other people have had problems with these two devices and IKEv2 VPN connections?
Cheers,F
- Netduma-FraserJul 21, 2020NetDuma PartnerSorry I should have been clearer, this section of the community is for the Nighthawk Pro Gaming range of routers - the XR300, XR450, XR500 & XR700. So to get more accurate answers for your issues then posting your questions to the Nighthawk link above would be better.
