Felix24343
Jul 19, 2020Aspirant
IKEv2 with MR1100
Hey all, I was wondering if anyone had used the MR1100 to connect to VPN on IKEv2? I have had issues connecting to my work VPN using this protocol and wondered if anyone else had this experience?...
Netduma-Fraser
Jul 20, 2020NetDuma Partner
Sounds like you have a different router to the XR series so would recommend posting in the Nighthawk section: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Felix24343
Jul 20, 2020Aspirant
Hi Netduma,
I have tried this with two netgear routers:
The Netgear Nighthawk M1 MR1100
And the Netgear AC800s.
I am wondering if other people have had problems with these two devices and IKEv2 VPN connections?
Cheers,
F
- Netduma-FraserJul 21, 2020NetDuma PartnerSorry I should have been clearer, this section of the community is for the Nighthawk Pro Gaming range of routers - the XR300, XR450, XR500 & XR700. So to get more accurate answers for your issues then posting your questions to the Nighthawk link above would be better.
