CrocOnA3Wheeler
Mar 06, 2019Aspirant
I'm at Wits End with the XR500 Nighthawk (Upload speed drop)
I want to love this router, I really do...However it leaves me with more headaches than it should. My Dad is on the verge of returning it.
I just started streaming through my PC not too long ago......
Mar 07, 2019Guru - Experienced User
What FW is currently loaded?
- Netduma_JackMar 07, 2019NetDuma Partner
Very odd you are getting such low speeds. Could you do this please:
- Go to QoS on the user interface. On Anti-Bufferbloat, click the three horizontal lines in the top left corner. This will expand Options. From there, could you check 'Disable QoS' and click Proceed at the warning message that appears
- Wire a PC or laptop into your router. Then go to speedtest.net - what speeds do you get on the test?
If your speeds are good, could you then repeat the test over wireless. My thinking is the problem is either with the WiFi, or a misconfigured setting in DumaOS. We'll be able to help you figure it out :smileyhappy:
