Compoza_
Jul 27, 2021Luminary
I'm getting tired of this
The XR500 gaming router dosen't eliminate "shoot first, die first", I have set the congenstion control, portfowarding, still happens.
Netduma-Liam
Jul 27, 2021NetDuma Partner
Hey Compoza_
Unfortunately, this issue is one that's very difficult to measure, but a lot of users on our forum (forum.netduma.com) have shared their personal configurations and setups that worked for them. You could check that out if you wanted to!
I can also try to assist, if you could just share a screenshot of your current QoS configuration I can make suggestions as to what needs optimising!
A few other questions:
- Are all devices on the network connected to the XR500?
- Are you using Geo-filter to ensure you're always connected to local, low ping lobbies? Or are you using it to play on more distant servers?
- Are you experiencing this same issue in every game, or do you find that you have some good games and some bad games?
Compoza_
here is the Qos pictures taken https://imgur.com/a/SbkF1hF
question 1: Yes
question 2: yes, but at the moment, I have disabled it because SBMM in COld War takes longer to find a match, between 10-20 minutes, when I have geo filter enabled.
question 3: yes I experience it in every game, shoot first, die first
