Compoza_
Jul 27, 2021Luminary
I'm getting tired of this
The XR500 gaming router dosen't eliminate "shoot first, die first", I have set the congenstion control, portfowarding, still happens.
Compoza_
here is the Qos pictures taken https://imgur.com/a/SbkF1hF
question 1: Yes
question 2: yes, but at the moment, I have disabled it because SBMM in COld War takes longer to find a match, between 10-20 minutes, when I have geo filter enabled.
question 3: yes I experience it in every game, shoot first, die first
Netduma-Liam
Jul 27, 2021NetDuma Partner
OK thank you, currently I don't believe QoS will quite have full control over the network. I'd suggest reducing this much further to arond 30-40%, though this will require some trial and error testing.
With Geo-filter disabled, where are the servers you're getting put on? Are they still local? What's the average ping you're getting from these games?
- Compoza_Jul 27, 2021Luminary
Where is the confirmation that anti buffer float is optimised? What do you mean with trial and error? Where can I see when I have set it right?
the avarege ping is 50 ms
- Netduma-FraserJul 27, 2021NetDuma PartnerThere is no confirmation when it is set up optimally as this is different for every single connection and most people like to go on how the game feels rather than certain ping stats. Trial and error as in trying a percentage, see how it feels in game etc, rinse, repeat. Where are you located roughly and where do you usually try to force games using the Geo-Filter.
