bretp2020
Sep 29, 2022Aspirant
im having connecting issues please help
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, September 29, 2022 21:53:01 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thur...
Netduma-Liam
Sep 30, 2022NetDuma Partner
Can you describe in a little more detail the problem exactly? The logs you've provided are just automatically printed during the start-up process, so they don't suggest any specific issue to us.
- bretp2020Sep 30, 2022Aspirant
Im getting connectivity issues with a lot of dos attacks i think that is what is making my internet go off then right back online.
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:48:39
[DoS Attack: TCP/UDP Echo] from source: 94.102.61.29, port 34349, Friday, September 30, 2022 09:48:18
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:47:43
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:47:03
[admin login] from source 192.168.1.2, Friday, September 30, 2022 09:46:51
[admin login] from source 192.168.1.2, Friday, September 30, 2022 09:30:19
[admin login] from source 192.168.1.2, Friday, September 30, 2022 09:29:41
[DoS Attack: SYN/ACK Scan] from source: 51.38.105.47, port 7757, Friday, September 30, 2022 08:53:37
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 08:52:23
[DoS Attack: SYN/ACK Scan] from source: 46.174.50.8, port 443, Friday, September 30, 2022 08:51:51
[DoS Attack: SYN/ACK Scan] from source: 222.92.255.14, port 5963, Friday, September 30, 2022 08:38:58
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 08:18:51- FURRYe38Sep 30, 2022Guru - Experienced User
Do a whois lookup on those WAN IP addresses you see.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the DHCP IP address range set for currently? Try 192.168.1.100 to .200
V1.0.1.59
Modem Netgear CM1000
Router XR700
Modem is connected to Router
LAN cable is CAT 6 No Flat cables
