bretp2020
Sep 29, 2022Aspirant
im having connecting issues please help
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, September 29, 2022 21:53:01 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thur...
Netduma-Liam
Sep 30, 2022NetDuma Partner
Can you describe in a little more detail the problem exactly? The logs you've provided are just automatically printed during the start-up process, so they don't suggest any specific issue to us.
bretp2020
Sep 30, 2022Aspirant
Im getting connectivity issues with a lot of dos attacks i think that is what is making my internet go off then right back online.
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:48:39
[DoS Attack: TCP/UDP Echo] from source: 94.102.61.29, port 34349, Friday, September 30, 2022 09:48:18
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:47:43
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:47:03
[admin login] from source 192.168.1.2, Friday, September 30, 2022 09:46:51
[admin login] from source 192.168.1.2, Friday, September 30, 2022 09:30:19
[admin login] from source 192.168.1.2, Friday, September 30, 2022 09:29:41
[DoS Attack: SYN/ACK Scan] from source: 51.38.105.47, port 7757, Friday, September 30, 2022 08:53:37
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 08:52:23
[DoS Attack: SYN/ACK Scan] from source: 46.174.50.8, port 443, Friday, September 30, 2022 08:51:51
[DoS Attack: SYN/ACK Scan] from source: 222.92.255.14, port 5963, Friday, September 30, 2022 08:38:58
[DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 08:18:51
- FURRYe38Sep 30, 2022Guru - Experienced User
Do a whois lookup on those WAN IP addresses you see.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the DHCP IP address range set for currently? Try 192.168.1.100 to .200
- bretp2020Sep 30, 2022Aspirant
V1.0.1.59
Modem Netgear CM1000
Router XR700
Modem is connected to Router
LAN cable is CAT 6 No Flat cables
when you say "Do a whois lookup on those WAN IP addresses you see" what should I be looking for? I see a lot of information.
1 address is from Moscow and Germany
