flewdurr-flam
Feb 09, 2024Follower
I'm not sure if this will help anyone
I'm not sure if this will help anyone, but my Nighthawk was red, but I noticed it needed an update. After the update, the Internet light went Green. It was curious because even with the Amber Internet light, we had internet. FYI.
1 Reply
What modem/gateway is it connected to?
You can get that with a double nat.
And if you're in a double nat, it can increase your ping/latency (reduced the benefits of a gaming router)
