josephquake
Feb 15, 2021Tutor
I'm tired of blocking servers
I cannot block the servers that I do not want to connect in real time because it takes too long to show me the information I bought the router to have a good time I am all the time disconnecting myse...
Netduma-Fraser
Feb 15, 2021NetDuma Partner
You don't need to block servers manually at all. All you need to do is set your radius and then it will block anything outside and allow everything inside automatically.
- josephquakeFeb 15, 2021Tutor
I don't know why it gave me so much trouble
- Netduma-LiamFeb 16, 2021NetDuma Partner
Have you tried setting up Geo-filter as Fraser suggested?
That will automatically block most of the bad servers you could connect to and drastically improve your experience.
- josephquakeFeb 16, 2021Tutor
what is fraser?
