blank_username
Aug 24, 2020Star
images sent from phone are failing and having issues
Hi All, I recently purchased an xr500 router and I've been noticing an issue when sending/receiving pics via text message. When sending, it will stall for awhile and then fail. Sometimes it goes ...
- Sep 05, 2020Could you try disabling MU-MIMO from there please - I'm not sure how new your phones are but might be they don't support it properly.
Netduma-Fraser
Aug 25, 2020NetDuma Partner
Are you using Smart Connect for WiFi? If so I'd recommend disabling this and try connecting to the 2.4/5GHz band manually. Would also suggest using a WiFi analyzer to find the least congested channel and change to that. See if that helps.
- blank_usernameAug 26, 2020Star
I disabled smart connect and connected to each band separately. They both do the same thing. A pic will send successfully at first (within the first 30sec to 1 minute of connecting) but if you wait, it will begin to stall and fail.
I checked the network monitor in the router UI and I have very little traffic happening at the time. There are only 2 additional devices connected to the 2.4 GHz and no additional devices connected to the 5 GHz
- Netduma-FraserAug 26, 2020NetDuma PartnerIn WAN Settings toggle SIP ALG, does that fix it?
I selected the box to disable SIP ALG and I'm still having the same issue
