Tkbuc
Nov 29, 2022Guide
In Game Latency
Hi everyone, Attached is a screenshot of in game latency details for an online game. I just factory reset my router and have a 1GB modem via Spectrum. Everything is working great. Every once in a...
Nov 29, 2022Guru - Experienced User
Not much to go off here.
Is this regarding a NG product? If so, need more details here.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- TkbucNov 29, 2022Guide
Im using the Nighthawk XR1000. The screenshot is the ingame latency data from the game client.
- FURRYe38Nov 29, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Are you wired or wireless connected to the router? Wired is preferred for gaming.
- Firmware Version 1.0.0.64
- Wired Connection with CAT 6
- Not using QoS
- Hitron Modem
- Model EN2251
- Spectrum is my ISP
- Netduma-FraserNov 29, 2022NetDuma PartnerAre you using QoS? If so could you provide a screenshot of the QoS page please? It could be a local congestion issue.
