ron_spruce
Dec 03, 2022Star
Inconsistent Speed Tests with XR1000
I have recently upgraded my home networking equipment from an Orbi RBR50 to the Nighthawk XR1000 Router. My speed test results are really fast when I connect my computer (2017 iMac) to my cable modem...
- Dec 04, 2022
Well I went ahead and did a factory reset on my XR1000 and that seemed to solve the problem. Not sure what happened to make the ethernet ports work so slowly but I'm glad it's not happening anymore.
Netduma-Fraser
Dec 04, 2022NetDuma Partner
What speeds are you getting through speedtest.net for example instead of Benchmark?
ron_spruce
Dec 04, 2022Star
I use both speedtest.net & fast.com which deliver similar results. I let the test site choose the best server.
