ron_spruce
Dec 03, 2022Star
Inconsistent Speed Tests with XR1000
I have recently upgraded my home networking equipment from an Orbi RBR50 to the Nighthawk XR1000 Router. My speed test results are really fast when I connect my computer (2017 iMac) to my cable modem...
- Dec 04, 2022
Well I went ahead and did a factory reset on my XR1000 and that seemed to solve the problem. Not sure what happened to make the ethernet ports work so slowly but I'm glad it's not happening anymore.
ron_spruce
Dec 04, 2022Star
- How are you doing these speed tests?
I'm using both speedtest.net & fast.com to do speed tests.
- And this computer is? What is the LAN chip?
The computer I'm using is a 2017 iMac and I attached the ethernet specs in a screenshot.
Thanks for your suggestions. I will check the more appropriate community.
Netduma-Fraser
Dec 04, 2022NetDuma Partner
Can you provide an attached screenshot of the table view on Device Manager please?
- ron_spruceDec 04, 2022Star
Netduma-Fraser wrote:
Can you provide an attached screenshot of the table view on Device Manager please?Connected to LAN port 3
- Netduma-FraserDec 04, 2022NetDuma PartnerYour pictures have to be moderated so I can't see them currently, if you attach them as an attachment I can download to view
Your pictures have to be moderated so I can't see them currently, if you attach them as an attachment I can download to viewattached
