ron_spruce
Dec 03, 2022Star
Inconsistent Speed Tests with XR1000
I have recently upgraded my home networking equipment from an Orbi RBR50 to the Nighthawk XR1000 Router. My speed test results are really fast when I connect my computer (2017 iMac) to my cable modem...
- Dec 04, 2022
Well I went ahead and did a factory reset on my XR1000 and that seemed to solve the problem. Not sure what happened to make the ethernet ports work so slowly but I'm glad it's not happening anymore.
ron_spruce
Dec 04, 2022Star
- FURRYe38Dec 05, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
