Derslyfox
Sep 01, 2019Aspirant
Increased latency with XR500
Hello, I dug through thr achived posts to see if there was anything addressing this situation or something I haven't tried yet. SETUP I have my console and pc hardwired directly into the router...
Netduma_Alex
Sep 02, 2019NetDuma Partner
Very strange. Have you tried different ethernet ports in the back of the router? Just checking there isn't a faulty port.
Derslyfox
Sep 02, 2019Aspirant
I have not tried a different port.
Never imagined that could be the issue.
I'll update with the results shortly.
- Netduma_AlexSep 03, 2019NetDuma Partner
I agree it seems unlikely, i'm just trying to rule things out.
- DerslyfoxSep 03, 2019AspirantYeah, I tried all the ports. Not a big enough change to rule that as the cause. I don't know what it could be, but I'm not worried about it at this point. I'll just accept the higher latency đ
- Netduma_AlexSep 04, 2019NetDuma Partner
I don't know what to suggest. I can't think of any settings that would cause this additional latency. This might be a hardware problem that requires a replacement.
