Pat1977
May 02, 2019Tutor
Info about XR500
I BOUGHT A XR500 ROUTER OF EBAY AND THE S/N IS REGISTERED UNDER SOMEONE ELSE EMAIL ADDRESS WHAT CAN I DO it's said contact Netgear support so I sent an email and it also says am in West coast usa but ...
- May 04, 2019We don't recommend accessing the interface via a mobile device as it's not optimised for that. Connect using a PC if possible try routerlogin.net if that doesn't work then use the IP address which is 192.168.1.1, can you access the interface then? What exactly did you change before the issue occurred?
Pat1977
May 03, 2019Tutor
Hi I did the set up and now it won't let me connect to the router even when I did what it asked now I don't know what to do I've even tried to reset it and still the same
Netduma-Fraser
May 04, 2019NetDuma Partner
- Pat1977May 06, 2019TutorThanks for the info and help I've connected now and sorry I've not seen your replys to me before now as I was Ill and couldn't move much
Thanks for all the help from everyone it's been well appreciated
