Vigilantslb
Feb 17, 2023Aspirant
Info Dumaos on router XR1000
Hi there, I don´t know why but i can´t log in on DumaOS. So i have a NightHawk XR1000 and i can´t access to DumaOS dashboard, i tried to go to routerlogin.net etc and it doesn´t work. Do...
Netduma-Fraser
Feb 17, 2023NetDuma Partner
By doesn't work, what are you seeing, what's happening exactly? Does using the LAN IP work?
- VigilantslbFeb 20, 2023AspirantHi,
So, when i write in the browser routerlogin.net or even the IP, just loads for some time and has one error.
Later i can send one print screen from it
Thank you- Netduma-LiamFeb 20, 2023NetDuma Partner
If you can send a screenshot that would be helpful.
Could you also try rebooting the XR1000, then see if you're able to access the interface after that?
