Vigilantslb
Feb 17, 2023Aspirant
Info Dumaos on router XR1000
Hi there, I don´t know why but i can´t log in on DumaOS. So i have a NightHawk XR1000 and i can´t access to DumaOS dashboard, i tried to go to routerlogin.net etc and it doesn´t work. Do...
May 19, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browser are you using? I use MS Edge with my XR1000.
Be sure to clear ALL Browser caches before entering the routers web page.
I just update FW on it as well:
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- VigilantslbMay 19, 2023AspirantHi,
Either i use google chrome, firefox or the app.
All my cables are cat 6- FURRYe38May 19, 2023Guru - Experienced User
Please try the suggestions.
I got my XR loaded up the other day and have not seen any issues on the web page. Though I would give loading of the dashboard time, does seems like it takes bit to finally load and display.
