RBosel
Aug 18, 2019Aspirant
"Innovative" DumaOS
Any idea when the DumaOS will work as advertised? Is anyone actually able to use this software? I have had this router for almost a year and the dashboard loads like I am using dial-up internet. Any ...
Aug 18, 2019Guru - Experienced User
Ask Christian_R for the beta. I also saw this slow UI issue when I had a XR700.
- Netduma-FraserAug 20, 2019NetDuma PartnerWould suggest beta firmware but also to double check are you trying to access the interface using HTTPS? If so then HTTP should be much faster.
