1733in2019
Jul 29, 2019Tutor
INTEL 9260 How To 1733 Mbps??
I have HT160 enabled with the latest firmware update for the XR500. Max speeds for 2.4 Ghz channel is set to 800, and 1733 for the 5 Ghz channel. (higher channels) 20/40 Coexistence is disabled. No...
- Jul 30, 2019
couple things.
Make sure the intel drive is the most current. Intel drivers have had issues lately in my experience. They've pushed out a couple updates lately that have helped with my 9260.
to get the 1733mbps link rate, 160 hrz channel width must be used. This utilize the lower 5ghz channels and the dfs frequencies. Are you able to enable the 160 hrz channel width?
What region do you have selected for your router?
Netduma_Alex
Jul 29, 2019NetDuma Partner
So you've got Smart Connect disabled right? It might be steering you to the lower band.
- 1733in2019Jul 29, 2019Tutor
Correct, it's disabled.
- plemansJul 30, 2019Guru - Experienced User
couple things.
- 1733in2019Jul 30, 2019Tutor
I will try new DFS frequencies as you've mentioned. I do have HT160 enabled. I think you solved my problem...
The chart in this link below shows 160hz isn't supported past channel 128... I will test the Channels 36-48 later today.
