Wynie
Dec 06, 2018Follower
Internet Dead xr500
Hey, Why is my internet suddenly gone and led light just turned flat orange. My Chorus ONT fiber box led lights are normally functioning as they should. Its just the router. Tried to reset but to not ...
Dec 06, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
