Gibbo44
Feb 03, 2020Aspirant
Internet dropped out last 2 nights
Hi, Just received this router and internet has dropped out last 2 nights roughly the same time. It was around 22:30 and I have attached the logs below. Both wifi and wired fails. If I plug my pc directly into the modem it would work fine. Any help would be appreciated.
[admin login] from source 192.168.1.2, Sunday, February 02, 2020 22:48:14 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, February 02, 2020 22:46:23 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, February 02, 2020 22:46:23 [DumaOS] DHCP new lease allocated., Sunday, February 02, 2020 22:46:21 [DumaOS] DHCP new event., Sunday, February 02, 2020 22:46:21 [DHCP IP: 192.168.1.2] to MAC address b4:2e:99:a0:bf:31, Sunday, February 02, 2020 22:46:21 [DumaOS] Error parsing line in ARP table: '2601:483:200:e14:cd37:a974:7727:2f1e dev br0 lladdr 70:ef:00:a9:75:1d STALE', Sunday, February 02, 2020 22:46:16 [DumaOS] Error parsing line in ARP table: '2001:558:6016:40::1 dev brwan lladdr 00:01:5c:65:3e:46 router REACHABLE', Sunday, February 02, 2020 22:46:16 [DumaOS] Error parsing line in ARP table: 'fe80::1659:c0ff:fe50:ef30 dev brwan lladdr 14:59:c0:50:ef:30 STALE', Sunday, February 02, 2020 22:46:16 [DumaOS] Error parsing line in ARP table: 'fe80::201:5cff:fe65:3e46 dev brwan lladdr 00:01:5c:65:3e:46 router REACHABLE', Sunday, February 02, 2020 22:46:16 [DumaOS] Error parsing line in ARP table: '2601:483:200:e14:cd37:a974:7727:2f1e dev br0 lladdr 70:ef:00:a9:75:1d STALE', Sunday, February 02, 2020 22:46:11 [DumaOS] Error parsing line in ARP table: '2001:558:6016:40::1 dev brwan lladdr 00:01:5c:65:3e:46 router REACHABLE', Sunday, February 02, 2020 22:46:11 [DumaOS] Error parsing line in ARP table: 'fe80::1659:c0ff:fe50:ef30 dev brwan lladdr 14:59:c0:50:ef:30 STALE', Sunday, February 02, 2020 22:46:11 [DumaOS] Error parsing line in ARP table: 'fe80::1463:600:74d6:e47c dev br0 lladdr 70:ef:00:a9:75:1d STALE', Sunday, February 02, 2020 22:46:11 [DumaOS] Error parsing line in ARP table: 'fe80::201:5cff:fe65:3e46 dev brwan lladdr 00:01:5c:65:3e:46 router REACHABLE', Sunday, February 02, 2020 22:46:11 [Internet connected] IP address: 98.211.16.218, Sunday, February 02, 2020 22:43:13 [Internet connected] IP address: 192.168.100.10, Sunday, February 02, 2020 22:42:10 [DumaOS] Error parsing line in ARP table: '2601:483:200:e14:cd37:a974:7727:2f1e dev br0 lladdr 70:ef:00:a9:75:1d REACHABLE', Sunday, February 02, 2020 22:41:03 [DumaOS] Error parsing line in ARP table: 'fe80::1659:c0ff:fe50:ef2f dev br0 lladdr 14:59:c0:50:ef:2f router STALE', Sunday, February 02, 2020 22:41:03 [DumaOS] Error parsing line in ARP table: 'fe80::1463:600:74d6:e47c dev br0 lladdr 70:ef:00:a9:75:1d REACHABLE', Sunday, February 02, 2020 22:41:03 [DumaOS] Error parsing line in ARP table: 'fe80::201:5cff:fe65:3e46 dev brwan lladdr 00:01:5c:65:3e:46 router REACHABLE', Sunday, February 02, 2020 22:41:03 [DoS Attack: SYN/ACK Scan] from source: 185.71.67.1, port 80, Sunday, February 02, 2020 22:28:05 [DoS Attack: SYN/ACK Scan] from source: 117.24.15.71, port 443, Sunday, February 02, 2020 22:16:38 [DoS Attack: SYN/ACK Scan] from source: 185.71.67.1, port 80, Sunday, February 02, 2020 21:50:27 [DumaOS] DHCP lease change., Sunday, February 02, 2020 21:49:07 [DumaOS] DHCP new event., Sunday, February 02, 2020 21:49:07 [DHCP IP: 192.168.1.8] to MAC address 7c:64:56:37:84:26, Sunday, February 02, 2020 21:49:07 [DumaOS] DHCP lease change., Sunday, February 02, 2020 21:03:15 [DumaOS] DHCP new event., Sunday, February 02, 2020 21:03:15
1 Reply
- Netduma-FraserNetDuma PartnerSo it is just once per day around the same time? This sounds like the DHCP lease is renewing at that time. Does the connection come back on its own or do you need to reboot the router? As there is no way to extend the lease I would suggest either rebooting the router at a time where you are not using the router, for example in the middle of the night. Otherwise if you set static IPs for your devices then they shouldn't lose connection.
