Rithveek
Jul 08, 2020Aspirant
Internet issue on wifi
Showing no internet connect when on wifi while internet is working fine ?
sabkuhh89
this error come when your internet LAN working fine but WIFI Network showing connected with error message " No Internet Connection". this is due to WIFI SSID configuration issue and sometime its due to router fault which broadcast the SSID but internet not working.....take help from herer routerlogin.net
- Netduma-FraserJul 08, 2020NetDuma PartnerIf you disconnect and then reconnect to the WiFi does it work?
- RithveekJul 08, 2020AspirantIf i again reconnect internet works but icon shows no internet connection, it has started from today only, previously everything was normal and ok.
- Netduma-FraserJul 08, 2020NetDuma PartnerDisable Smart Connect and see if it continues after that.
