Rithveek
Jul 08, 2020Aspirant
Internet issue on wifi
Showing no internet connect when on wifi while internet is working fine ?
Netduma-Fraser
Jul 08, 2020NetDuma Partner
If you disconnect and then reconnect to the WiFi does it work?
Rithveek
If i again reconnect internet works but icon shows no internet connection, it has started from today only, previously everything was normal and ok.
- Netduma-FraserJul 08, 2020NetDuma PartnerDisable Smart Connect and see if it continues after that.
