Gaines09
Aug 01, 2018Tutor
internet seems to drop out constantly and causes high latency while gaming
So I've been told by spectrum a few times that the problem is within my modem and router. I bought a new modem and router and I still seem to be having the same issues. It seems the internet connecti...
Gaines09
Aug 01, 2018Tutor
Both. When I'm watching videos sometimes my videos will begin buffering and then I'll run a speed test and the connection is non exsistent. Do I need to screenshot anything so you can see if you can diagnose it?
Netduma-Fraser
Aug 02, 2018NetDuma Partner
If this issue was present before you upgraded the router and modem and it is still present now then its certainly not the equipment that has an issue. Does it appear to happen at random times or in peak times mainly?
You can try disabling QoS in Anti-Bufferbloats options to see if that helps. Would suggest replacing all the ethernet cables connected to modem/router as well to ensure its not those either.
- Gaines09Aug 02, 2018TutorIt happens at random times and it’s very frequent. These are brand new Ethernet cables. I’ve already swapped those and it’s still happening. I have a feeling it’s the drop to my home but spectrum says otherwise. How do I check to see if the problem is on their end. They keep blaming it on my end.
- Netduma-FraserAug 02, 2018NetDuma PartnerI'd suggest roughly following this guide to get the evidence you need except when directly connected to the modem, no other devices using the internet http://support.netduma.com/support/solutions/articles/16000074717-test-your-connection
